Sky+ disk fragmentation
Discussion in 'Sky Digital TV Forum' started by NicolasB, Dec 11, 2003.
  1. NicolasB
    NicolasB
    Oct 3, 2002
    6,450
    Emily's Shop
    +898
    Does Sky+ have any way of defragmenting its hard drive? If not, has anyone tried removing the disk, placing it in a PC, defragging it, and putting it back in the Sky+ box again? If so, did the recordings survive, and was there any improvement in performance?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Housekeeping is the best way to clean up a HD but that's rather terminal for stored data:)
    I would suspect that the added RASP layer that SKY+ uses for indexing etc would make a PC defrag a waste of time or at worse totally destroy the data.
    Personally I think Housekeeping a disk every now and again is good for the system (Still using the orig 40gig) but it's probably all in my mind:)
  3. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    how do you do housekeeping on the disc?
  4. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    On the remote......
    Services
    4
    Select
    Then select option 7 (Full system reset) but be warned, IT WIPES EVERYTHING.
  5. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    thanks
  6. Azrikam
    Azrikam
    Not sure what OS Sky+ is running in the background, but TiVo uses Linux, so hard disk fragmentation isn't an issue like it is in Windows PCs. I would assume that either Sky+ uses an OS that doesn't fragment, or has a built-in defrag utility. (or maybe runs one automatically)
  7. Papua
    Papua
    Dec 16, 2002
    285
    Devon
    +28
    Have seen a sky+ disk connected to a pc and it is formated to FAT32. The files and folders didn't make any sense, but I reckon it could be defragmented by a windows pc.
