SKY dish on a pole
Discussion in 'Sky Digital TV Forum' started by Barry.NI, Jul 14, 2004.
  1. Barry.NI
    Barry.NI
    Jun 25, 2004
    446
    Chester
    +11
    Due to planning restrictions, my son wishes to put his sky dish on a 2 metre pole, at the rear of the house, with a wall bracket, fixed just below the soffit, in order to clear his neighbour's roof. Has anyone on the site got such an installation, and what was the diameter of the pole, and the type of brackets used, and were there any problems in windy weather?
  2. SimonO
    SimonO
    Nov 4, 2002
    3,293
    71
    Hertfordshire
    +64
    I've got a 65cm dish on a 2m x 40mm diameter pole to clear a roof... I made the mistake of fitting an aluminium pole which does move around in the wind, so go for steel and you'll be fine...
  3. Barry.NI
    Barry.NI
    Jun 25, 2004
    446
    Chester
    +11
    Many thanks
  4. Lex
    Lex
    Feb 7, 2002
    4,089
    61
    Cornwall
    +4
    My parents have theirs mounted on an old telegraph poll in the garden - they used the standard brackets that came with the dish. Works just fine :smashin:
    EDIT Sorry just re-read your post, I mis-read what you were asking :blush:
  5. richardys
    richardys
    Jul 19, 2004
    69
    9
    UK
    The old Sky dishes will only take a 1.25" pole. The new ones will fit 1.25" or 1.5" easy, but require a large U-bolt.
    I would recommend a T&K bracket.
  6. ndenbow
    ndenbow
    Oct 20, 2003
    493
    Herts
    +11
    My pole was supplied by the Sky installers, who later refused to fit the dish and cabling for insurance reasons (listed building, thatched roof etc). The pole is aluminium and is located at the end of my garden. Never had any problems apart from overgrowing trees and plants. I needed a larger dish to compensate for the extra cabling distance. I sprayed the dish green and now you can hardly recognise it, being creative with the sheers.
