Sky Dish Location
Discussion in 'Sky Digital TV Forum' started by sandy10, Aug 10, 2005.
  1. sandy10
    sandy10
    I'm working out the location of where i want to put my Sky dish.
    I know it must be 28 degrees South East, and the angle of projection etc.
    How unobstructed must the dish be - i'm concerned the adjoining properties in my terrace may slightly overhang the wall i want it on.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,263
    Manchester
    +755
    It would need to clear an angle of somewhere between 21 and 25 degrees elevation , depending on where you live (your latitude).
    I am sure elevation tables must exist somewhere on the web (or use SMWlink software downloadable from www.smw.se)
    To check once you know the required elevation, use a protractor and pipe, looking through the pipe at the required angle from where you could site the dish ; if a rooftop obstructs your view at the required angle , you need to find an alternative position for your dish .
    Chris Muriel, Manchester.
  3. SamRadford
    SamRadford
    Jul 12, 2005
    3,965
    103
    N. Yorkshire
    +308
