Sky dish installation
Discussion in 'Sky Digital TV Forum' started by fungus-fingers, Aug 23, 2004.
  1. fungus-fingers
    fungus-fingers
    Nov 23, 2001
    458
    +8
    Have moved house and cannot have my sky+ moved over/installed because of tall trees at the back of the house. Sky installation guy says trees are too tall for pole installation on roof. He suggested attaching a pole to the garden shed for mounting the dish because there was a gap in the trees which would allow a signal to pass through. This would require minimal tree surgery, just a few branches and some shrubbery to get rid of, as opposed to £1000 to top 2 large trees, which will of course grow again.
    Any ideas if attaching a pole to the garden shed will be robust enough? if so, what type of pole, fixings etc and where is the best place to get em (B&Q)?. Could the dish be attached directly to the garden shed? Any ideas greatly appreciated. Life is unbearable without sky+. I have kept my subscription running even though I cannot watch sky.
    Fungus
  2. Fernsehman
    Fernsehman
    A minidish will be fine on a garden shed, provided that the shed itself is not going to move!
    Most Sky minidishes will attach easily to a 1.5" diameter pole. (Some like the Triax version will need a "U" bolt - not supplied with the dish).
    If the unsecured section of pole (between mounting bracket and dish bracket) is more than about 600mm then I would use a 2" diameter pole.
    I think B&Q might sell the fittings. Otherwise try a mail-order company if you don't have a local aerial shop.
  3. fungus-fingers
    fungus-fingers
    Nov 23, 2001
    458
    +8
    Fernsehman
    Many thanks for the help. Just nned to get a little tree surgery done before calling out the Sky installation guy.
    Cheers :smashin:
    Fungus
  4. RBZ5416
    RBZ5416
    Nov 4, 2002
    18,353
    +6,871
    Tree surgery may not be as expensive as you think (depending on where you live). I had 9 x 30 foot Leylandii taken down to gound level last year for around £400. This didn't include stump removal but was a lot less than I was expecting to pay. My guy was based in North Essex & was fully qualified & insured. PM me if you want his details.
  5. fungus-fingers
    fungus-fingers
    Nov 23, 2001
    458
    +8
    Crocodile
    Many thanks for the offer, but I live in Belfast so asking him to come over here may be costly. I'll get a guy out next week to give me a quotation and take it from there.
    Fungus
