sky + dish help
Discussion in 'Sky Digital TV Forum' started by jason t, Jan 7, 2004.
  1. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    hi i have got sky + with a standard dish but wanted to upgrade my dish to a 60cm would it be ok to use the old 60cm analogue dish or would a new 60cm digital dish be better??
    thanks
    jason
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    The Quad LNB is matched to the oval shape of the SKY minidish (zone 1 & 2), you would probably lose the benefit of a larger dish by using a mis-matched LNB.
    So either use a Zone 2(60cm) SKY minidish or get a standard 60cm dish and a new LNB.
  3. wod
    wod
    Sep 7, 2003
    196
    +3
    change the dish to a zone 2 as you can then still use the lnb on it and it will give you a better signal in bad weather.
    you could use a round 60cm dish but you would need to buy a quad lnb or 2 lnb with a 40mm collar
  4. jason t
    jason t
    Mar 4, 2001
    1,707
    48
    kent
    +38
    i have seen a collar that makes a 23mm lnb into a 40mm one and it can then be fitted to a offset dish !!! but what i am worried about is this wont be as good as a zone 2 dish which hopefully would fit on to my bracket that i already have installed (no more holes to drill)
    jason
  5. wod
    wod
    Sep 7, 2003
    196
    +3
    yes go for the zone 2 as the holes should be the same in the bracket and add the quad lnb.
    the round dish would look out of place now against the other dishes in your street
