Sky dish bracket mounts
Q
Quixote
hey, was wondering if anyone could help me, I need to find out what the standard bracket dimensions are that are used with a standard 60cm sky dish installation.
Trying to do a planning application to get it mounted on a listed building and theyre quite pedantic about what size the mounting will be on the wall. :boring:
Archie Fax
I've got a spare minidish in my loft. The outer edge of the fixing bracket is 16cm long x 10 cm wide.
