Sky+ disc problem?
Discussion in 'Sky Digital TV Forum' started by Mr Ed, Jul 3, 2004.
  1. Mr Ed
    Mr Ed
    Jul 24, 2002
    26
    3
    South Manchester
    We have a Sky+ v2 box that is about 7 months old and I've noticed that the available disc space doesn't tally with the % used on the recorded programs.
    Currently, we have 2 programs recorded of 1 hour each, totalling 8% of disc space used, but the free disc space is indicated at 66%. I know that the instant rewind (set at 30 mins) will use a couple of %, but we appear to be missing about a quarter of our disc space.
    When new, we had free disc space in the 90%'s in these situations.
    Have we got a problem that I need to talk to my satellite man about or is this something else beyond my control?
    Cheers,
    Ed.
  2. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    This is a common fault that can be cured by a full system reset. Watch all the programmes you want to first as they will be erased in the process. Press "Services" then 4,0,1 "Select" on your remote, which should bring up a hidden menu which allows you to access it (Option 7). Wait for it to finish and wait a further minute once it has switched itself off.
    Hope this helps :)
    p.s. Check all your settings afterwards such as instand rewind times and record buffers.
  3. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    Bradford, West Yorkshire.
    +324
    I wouldn't say this was 'a common fault'. The HD just needs to be 'defragged' as it would on your PC. It's basic maintenance really.
    RCT's solution will cure it.
    A. Dork
  4. rct
    rct
    May 16, 2002
    986
    South Wales, UK
    +3
    AFAIK it isn't a defragmentation issue, space would not be "lost" in this case, access times would merely increase. As for common, it has been in my experience I've had to do this or explain this to several friends' Sky+ units. I've had to reset my own Sky+ boxes 3 times for the same fault.
  5. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    +324
    I'm no computer expert, so I could be wrong. Thought it was a pretty decent explanation myself though. If anyone can come up with a definitive reason for this 'fault' and prove me wrong I would be happy to learn. ;)
    Whatever the cause - as I said, RCT's solution will cure it.
    A. Dork
  6. Mr Ed
    Mr Ed
    Jul 24, 2002
    26
    3
    South Manchester
    Many thanks! Back to 100%.
    Ed.
  7. Lawe
    Lawe
    Dec 30, 2003
    123
    19
    Hampshire
    Well thats answers my question I was going to ask!
    However, a quick question to ask is, if I do a full reset, will I lose all the pre-planned recordings and series links that I have lined up?
  8. GGTVBD
    GGTVBD
    Feb 5, 2004
    3,396
    +324
    Lawe - Yes!
    A. Dork
  9. Lawe
    Lawe
    Dec 30, 2003
    123
    19
    Hampshire
    Thought as much :suicide:
    Cheers mate. :thumbsup:
