Sky digital
Discussion in 'Sky Digital TV Forum' started by adamjt7, Oct 20, 2005.
  1. adamjt7
    adamjt7
    Nov 12, 2004
    14
    3
    +3
    Can anyone shed any light on this problem plz i moved my sky box the other day and when i pluged it all back in there was no picture but i had sound i plug my digi box in using a scart lead.I tried the scart with my dvd player and that worked fine.
  2. Jules1975
    Jules1975
    Are all the scart leads pushed in fully? I have had this problem, you only need one slightly out to lose the picture.
  3. adamjt7
    adamjt7
    Nov 12, 2004
    14
    3
    +3
    Yes i`ve tried 3 different scart leads and made sure they were all plugged in fully.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Just confirm that the TV scart input is correct for the feed it is receiving from the digibox, it may be looking for composite and getting RGB or vice versa, it may even be expecting s-video.
    Try the other scart output on the digibox as well and the RF just to confirm there is video being sent.
  5. adamjt7
    adamjt7
    Nov 12, 2004
    14
    3
    +3
    nothing as been changed on the set up of the tv and digibox just unplugged it and moved it and plugged it back in......no picture but sound .....
  6. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Software can be a tricky thing, switching power off and then back on has been known to wipe previous settings which is why you should always check, better safe than sorry:)
    Have you tried the VCR scart output and the RF's to confirm there a signal being generated and while you have tested various cables were they all two way?
  7. maybepoet
    maybepoet
    I HAVE A SKY DIGI BOX AND WISH TO BE ABLE TO RECORD PROGRAMMES. i HAVE NO VIDEO RECODER BUT I DO HAVE A GOOD DVD PLAYER. CAN ANYONE SUGGEST THE BEST METHOD OF RECORDING PROGRAMMES? I DO NOT WISH TO HAVE SKY + AGAIN (NOT AFTER 12 DUFF BOXES!!)
  8. Bluevanman
    Bluevanman
    There's no need to shout. If you connect your DVDR,providing your model is a recorder, to the VCR scart on the Sky box you should be able to record the channel the box is showing.
  9. Heinz
    Heinz
    Aug 4, 2005
    408
    Earle Colne, Colchester
    +15
    A DVD player cannot record.
  10. maybepoet
    maybepoet
    Is there no way of recording other programmes other than the one I am watching?
  11. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    Yes, Sky+ ...... it's what it was designed to do.
  12. maybepoet
    maybepoet
    Did you bother to read my message? I had 12 defective sky+ boxes and now rely on a free sat digibox which does not malfunction.
  13. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +272
    If you take that sort of attitude, nobody will read your messages :thumbsdow
