Sky Digital.
Discussion in 'Sky Digital TV Forum' started by superallyk, Jun 13, 2009.
  1. superallyk
    superallyk
    Mar 21, 2009
    10
    Hi there.
    I've had long spats with my Sky and tonight its taken a whole new step.
    Right now we use multiroom, and downstairs the sky plus is working away perfectly... however.
    In my room, i have Sky Plus, which (dailly at the exact same time) locks then says "no satellite signal is being received 29", to which i turn off.
    Normally when i put my normal Sky Digital box in it works fine and i get the channels until around 8pm when Sky+ magically works again, however this isnt the case tonight.
    At the moment my Sky Digital isnt giving me a satellite signal still, and as mentioned things downstairs are working fine still.
    All my settings have been checked, and the cabling looks in fine nick too, thus why im at a loss.
    Can anyone help with this issue?.
    cheers
    -ally
  2. Trollslayer
    Trollslayer
    Feb 11, 2007
    24,613
    Poole
    +9,847
    Silly question - does the signal go through a splitter? If so and someone watches a partticualr program at 8pm this could do it. If so the cure is separate feeds to the LNB.
  3. superallyk
    superallyk
    Mar 21, 2009
    10
    i dont think it dos, it goes straight to the dish.
    Still having the same problems 24 hours later though.
  4. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    The SKY+ bedroom box works on the dish feeds downstairs?
    I've other reports were 29 is considered a hardware issue so if the box doesn't work on the feeds it may need replacing.
  5. superallyk
    superallyk
    Mar 21, 2009
    10
    i've tryed my normal sky digital box, my sky+ box and my mothers sky + box (all three work fine down stairs also).
