Sky Digital Technical Information Question
Discussion in 'Sky Digital TV Forum' started by adc2000974, Aug 11, 2003.
  1. adc2000974
    adc2000974
    Hello AV Forums
    Whilst having Sky Digital for ages, i've never really wondered, about the tech info, like the dab radio stations are mostly in 128kbps and some like bbc radio three are higher, (i believe thats correct), as i've read it in an Home Cinema Mag, I could of mis-understood.
    I would like to know other specifications also, just to feed mine and others curiousity really.
    Thanks to all whom reply.
    Regards, Adam C.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,257
    Manchester
    +753
    I had a look at the real-time bit-rate within the MPEG transport stream (I have a transport stream reader)
    Radio 3 : 190 kbps
    Radio Wales : 110kbps
    Radio 2 : 200 kbps
    RTE1 : 100 kbps
    WRN : 100 kbps
    Radio Caroline : 70 kbps
    Interestingly Radio caroline was the only one with the Max Bitrate Flag set - but this was meaningless as it was set at 3.95 Mbps !
    This was just a snapshot tuning to a couple of the muxes with radio channels therein during a quick 5 minutes.
    Readings taken using Twinhan VP-1020 PCI card + registered version of TSReader http://www.coolstf.com/tsreader
    Chris Muriel, satellite anorak
    (Can email the TSReader screengrab for specific muxes to you if it means anything to you).
  3. adc2000974
    adc2000974
    Regards
    Adam C
  4. Gazkicka54
    Gazkicka54
    May 11, 2003
    Hi Chris, I like all the bit-rate stuff, what's ITV, Sky One, and some of the BBC channels averaging and can you tell the resolution of the chans e.g. 720x576 etc?
    Nice one!
    Gar
  5. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,257
    Manchester
    +753
    I had a look at a few of the relevant muxes between 1220 and 1235 AM (wee small hours).
    On a BBC Mux : BBC NI fastest @ 4.70 Mbps.
    Then BBC News24 - 4.19
    BBC3 - 3.57 BBC1 London - 3.20 BBC2 England - 1.9 Mbps
    ITV Mux : varied between 2.67-2.75 over the regions
    Sky1 : Varying at quite an instantaneous rate between 2.3 - 2.8.
    (total Mux was 35 Mbps on this one).
    Only BBC3 gave resolution info in the headers - 720 x 576i, 16:9.
    This took quite a long time to compile :-(
    Chris Muriel, Manchester.
  6. Gazkicka54
    Gazkicka54
    May 11, 2003
    Really is appaling for a public service broadcaster having VCD braodcasts...
    Sky - I expected nothing less, bad-terrible-bad, really is the quality benchmark (lowest) for the industry!
    Thanks Chris for your time!!!
    Gar
  7. Wayne Moule
    Wayne Moule
    Aug 4, 2000
    1,874
    3
    48
    +78
    Which explains why The Premiership is crap quality on ITV,roll on Match Of The Day!
    What's the rates of BBC 1 etc?
