Sky Digital Signal Mce Setup
Discussion in 'Microsoft Windows' started by powerhousedan, Jun 21, 2005.
  1. powerhousedan
    powerhousedan
    Just wondering the Best way to hook up my Sky Box to my Pvr150,
    The chances are my Digi Box wont have S video(Just ordered Multi Room so depends wat box i get with it), So whats the best way of hooking it up.When i go to tune in the signal to mce I go cable/digital?
    Choose yes to a set top box?Put the Blaster in front of the IR in the Digi box.
    ?Anything i'm missing or should do?
    Thanks in Advance.
  2. powerhousedan
    powerhousedan
    Sorry i just found the other post last month someone askin the same question, I've a scart to composite converter so that should work?
