Sky Digital Questions
Discussion in 'Sky Digital TV Forum' started by donjayok, Sep 8, 2003.
  1. donjayok
    donjayok
    Aug 3, 2003
    100
    Dundee
    +8
    I have had sky digital now for about a year and yesterday I got it wired up to my bedroom in another part of the house which works perfectly.
    My question is, Is it possibly to view different sky digital channels at the same time in the different rooms?
    A friend put me onto the following website, but he wasn't sure if you could watch different channels or not.
    Sky Accessories
    With reference to the products on the above website, am I correct in saying that If I bought the TV/Link magic eye product, then I would be able to change the sky channels from the bedroom, but it would also change it in the living room.
    And if I bought the 4 way amps with IR product, then would I be able to watch Sky digital or Terrestrial channels on one or both TV's? Where would it be situated? At the Sky box?
    Thanx in advance for any replies, much appreciated and sorry for being stupid! I am just learning! :rolleyes: :)
  2. MAW
    MAW
    Jan 24, 2002
    14,082
    Nr Dorking
    +412
    Your sky box can tune to 1 channel at a time. This will be the one watched no matter which room you are in, and no matter how many rooms you've got wired. You can arrange to change channels from any room. You should be able to watch terrestial TV independently with that device, and also any terrestial channel on any TV, and 1 sky channel on any TV, at the same time.
  3. Garrett
    Garrett
    Apr 21, 2001
    31,439
    2
    The best thief you’ll never see.
    +4,028
    As above says only one channel at a time.
    It is like having a radio connected by speakers in other rooms, only one station/ frequency can be tuned into one at a time.
  4. donjayok
    donjayok
    Aug 3, 2003
    100
    Dundee
    +8
    Thanx very much guys .........expertly explained! :smashin:
  5. wod
    wod
    Sep 7, 2003
    196
    +3
    you need a separate box to view another channel in another room
  6. SignalMan
    SignalMan
    Mar 8, 2002
    345
    West Yorkshire
    +22
    Sky Plus will give you up to 3 rooms with different channels but can prove expensive, tho I think Sky are doing away with some charges from next month
