sky digital product code
Discussion in 'Sky Digital TV Forum' started by Elektron, Dec 10, 2003.
  1. Elektron
    Elektron
    hi folks quick question 4 ya.
    how do i find my sky digital product code (the 4 digit one) so i can programme annother remote to use it?
  2. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    Not sure if there is one. It is usually done via infra-red. I maybe wrong though!!
  3. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    BTW I am assuming you are not trying to programme another Sky control. If you are you can do this by pushing:-
    TV
    Blue+select (led flash twice )
    2
    Select
    Sky
    This is a code for Sky+ for converting your old Sky control to work on it.
  4. Elektron
    Elektron
    no i have just got me a yamaha home movie processor and the remote is multi functional i was wondering if the sky digital box had a product code so i could just use this remote insted of the sky remote
  5. MarkR
    MarkR
    May 3, 2003
    1,849
    Somewhere in Kent
    +299
    If you programme the Sky controls by using codes like TV Blue+select, 2, Select, Sky, then I cant imagine there be any other sort of code.
    I may be wrong though!!:(
  6. sinbrad
    sinbrad
    I've got the DSP-AZ1 and it too comes with a multi-functional remote. Being a failry new amp the remote is pre-programmed with most codes. You should be able to follow the instructions to follow how to setup your remote in the user's manual. You have to select the manufacturer of the sky box ie panasonic, pace etc. It will give you the basic functions. You will then have to use the learning facility to insert any actions that you will need. Hope this helps
