SKY+ Digital Output
Discussion in 'Sky Digital TV Forum' started by TheDufster, Aug 22, 2002.
  1. TheDufster
    TheDufster
    May 21, 2002
    99
    11
    Leeds
    I am considering getting SKY+ (altough I just phoned them to try and get the £199 deal and they said they knew nothing about it), however my question relates to the digital output on the back of the SKY+ box.
    I have a 5.1 Amp (Sony STRDB1070) which has only one digital COAX type input, the others are the 'squarer' type sockets. Is this compatible with the SKY+ digital output?
  2. lmccauley
    lmccauley
    Oct 24, 2000
    3,560
    Newcastle
    +343
    The Sky+ box has a single optical digital output. I think this will be the square inputs on your Sony amp.
    Cheers,
    Liam
  3. gringottsdirect
    gringottsdirect
    Jan 11, 2002
    2,917
    71
    50 Rue St Georges, Paris.
    +32
    Yes.
  4. caziain
    caziain
    I also have a 1070 and the output from Sky+ is indeed optical and works perfectly with the Sony.
  5. common
    common
    Mar 5, 2001
    1,397
    41
    Oxford UK
    +8
    I take it you still need phono's for everyday viewing/listening via your amp and the optical is only for 5.1 broadcasts ?
  6. philipb
    philipb
    Mar 6, 2002
    2,100
    63
    Swindon
    +175
    You can use the optical out for all sound from Sky. In fact it will improve even stereo sound because the feed stays digital for longer.
  7. Choddo
    Choddo
    "improve" stereo sound?! That's the understatement of the century. Considering the DAC in my Sony 930 is probably about 10 times better than that in the standard digibox, plus as you say, the reduction in analog connections & cabling, the difference in stereo sound is absolutely amazing.
    I haven't watched anything transmitted in 5.1 yet, but I look forward to it.
  8. Beefer
    Beefer
    Aug 7, 2002
    52
    Gloucestershire
    I've had SKY+ for a few months now but only just connected it to my amp (due to decorating! ahhhhh) via the optical digital feed.
    Switched it on one evening while X-men was showing on sky P W/S in DD5.1 and was blown away! Excellent :)
    Scott
  9. Fairzo
    Fairzo
    Apr 8, 2002
    107
    16
    So can I get rid of the analogue connections completely then?
  10. Choddo
    Choddo
    Yeah, the only reason I use them at all now is for the sound from my Gamecube which has no digital out but does support DPL2
    Chods
