Sky+ Digital Out
Discussion in 'Sky Digital TV Forum' started by Jon Baker, Sep 24, 2001.
  1. Jon Baker
    Jon Baker
    Jul 22, 2001
    48
    Cumbria
    Ditto the audio setup.
    I think I have seen some lip sync problems but I just assumed it was the source material.
    Have you tried switching back to normal to see if the lip sync is ok ?
    Have you tried an analogue connection ?
  2. Banjaxe
    Banjaxe
    Dec 1, 2000
    63
    +3
    Hi Jon,
    I put my audio setting back to normal and the lip sync seems fine again.
    I think some material can be borderline to begin with and adding any extra delay can make it cross the threshold where it becomes really noticable.
    As a test I was going to try comparing the analogue out through the tv speakers against the digital out through the hi-fi and see if I could hear the delay and if there was any difference between the "Normal" and "Dolby Digital" settings. I'll give that a try later and post the results tomorrow.
    Ronnie
  3. Banjaxe
    Banjaxe
    Dec 1, 2000
    63
    +3
    Has anyone else tried setting their Sky+ box to output Dolby Digital ?
    I thought I'd try it to see if the box would output PCM if there wasn't a Dolby Digital signal being transmitted and sure enough it did. My reasoning being that I could then leave the box in DD mode and automatically get the benefit whenever the transmissions start.
    However - and I might be imagining things here - it seems that when I do this I can notice a slight lipsync error. The audio seems to be delayed slightly with respect to the picture.
    Considering that Dolby Digital isn't offically available yet I'm not complaining - I just wondered if anyone else could see this.
    Hopefully, even if I'm not imagining things and the lipsync problem is there, a software update before the official launch of DD will be all that's needed (my Sky+ box has already updated itself at least once).
    Ronnie
  4. mart.stokes
    mart.stokes
    I used to see lipsync errors on my old digibox but it depended on the channel. I've watched a lot of CNN recently and that IS bad, also Eurosport can be a bugger at times.
    I'll have a close look tonight. Yes, I have left mine at Dolby D setting so my amp is only seeing PCM at the moment.
  5. mart.stokes
    mart.stokes
    You've all got better eyesight than me, I cannot spot it (and therefore I'm happy), but don't deny it could exist to the more critical eye.
  6. Banjaxe
    Banjaxe
    Dec 1, 2000
    63
    +3
    I tried comparing the two settings again last night and have to admit that I couldn't see any difference between them. Both settings seemed fine so I left the box set to output Dolby Digital whenever it starts.
    The last time I tried was when I got the Sky+ box installed last Tuesday and since then it's definitely received an upgrade of at least the EPG.
    I'm pretty sure the problem was there when I first tried it but as long as it's not there now I'm not complaining <img src="smile.gif" border="0">
    Sorry about the wild goose chase.
    Ronnie
  7. rdg
    rdg
    Jul 15, 2001
    83
    I don't know whether a fault has developed, it's morphic resonance, or just plain suggestibility, but during some programmes, mouths were moving differently from the sound.<br />I couldn't be clear what direction this was in as I have the option of altering the lip-synch on my processor. I also am not sure if it will vary much from programme to programme.<br />It reminds me of the early problems with DVDs, although not as bad.<br />After all the installation problems, the cost, we can now look forward to finding all the bugs.<br />Perhaps this is due to a software upgrade?<br />Whatever, it is there.
