Sky+ Digital Out
Discussion in 'AV Receivers & Amplifiers' started by stevecc, May 19, 2005.
  1. stevecc
    stevecc
    May 16, 2005
    23
    I wonder if anyone can help me please....
    I currently have a standard SKY box, which is SCART connected to my TV.
    I am thinking of getting SKY+, and notice that these new boxes have digital out, so they can be connected to my AMP.
    If I were to connect the SKY+ box to my amp using digital out, but leave main connection to TV via SCART, does this mean that I could listen to SKY+ via my amp with Dolby Digital sound (depending on signal being received of course!) AND - when required - leave my amp turned off, and just listen to Sky through my normal TV Speakers via the SCART connection?
    If not, how could I acheive this?
    As always, thanks in advance for any help.
  2. Astaroth
    Astaroth
    Suspended
    Jun 22, 2004
    3,653
    2
    London
    +882
    Yes you can achieve that exactly how you said
  3. Cable Monkey
    Cable Monkey
    Feb 10, 2002
    3,494
    Birmingham
    +205
    Most kit that provides digital and analogue outputs usually have them work simultaneously for the very reasons you quote steve. My old Nokia 221 mediabox (freeview) output to both analog and optical at the same time and I just chose how I was going to listen to it. The Scientific Atlanta cable box Telewest uses has optical out too.
  4. stevecc
    stevecc
    May 16, 2005
    23
    Thanks for your help guys....that has answered my question!
    Appreciate it.
