sky+digital out
Discussion in 'Cables & Switches' started by carmine, Oct 1, 2004.
  1. carmine
    carmine
    my sky receiver is about 8 metres from my av amp can i still connect these to together using this method and if so does anybody sell this length of digital cable cheers.
  2. Stellavision
    Stellavision
    Apr 7, 2003
    2,410
    Southsea, UK
    +105
    I have never heard of an optical cable this length. Off the top of my head I am thinking that optical to coaxial with a Maplins convertor would be a good option, as coaxial cables are much easily aquired in longer lengths.
  3. Ozzy
    Ozzy
    Nov 11, 2000
    37
    Scotland
    Don't know much about use of fibre optics for audio, but in IT you can have fibre links up to 2.5km, so I hardly think 8m should be a problem for the cable technology.
    I've seen 10m cables advertised here
    Not very expensive, so can't speak for the quality but I'm sure you could probably hunt down a similar length of TOSlink cable from a well-known manufacturer.
    Stefan
