Sky Digital Icons
Discussion in 'Home Cinema Control & Remote Controls' started by philthyanimal, Jan 13, 2004.
  1. philthyanimal
    philthyanimal
    anyone know where ican get a sky+ ccf and channel icons for a ru940.
    I've tried remote central but that seems to be an american site with hardly any sky.
    Also, are the icons bitmaps, jpegs or gifs?
    Can i create my own on my PC?
  2. Messiah
    Messiah
    Apr 22, 2002
    7,534
    +339
  3. MarkE19
    MarkE19
    Aug 10, 2002
    17,132
    Rainham Essex
    +2,393
    I've seen loads of channel logos etc on remote central for the UK.
    Go to the files section and then to the pronto section. Scroll down the page to the CCF & software links. You just need to work your way through them to find what you are after. Craig Barnes' Sky Digital & ITV Logos are about 2/3 of the way down the logos area under Component Configuration Files. The logos etc are bitmaps. From the same area as above on RC you can get a prog that will convert images to 2, 4 & 8 bit images that can be used by your remote. Bitmap converer can be found under Progs, Utilities & Docs > Other Progs > ImgRep
    HTH
    Mark.
  4. John
    John
    Dec 13, 2002
    11,011
    +2,688
    On the digitalspy site there is a page with all the channels with their numbers (thats very usefull in itself :smoke: ) and logos where available have a look :clap:
