sky+ (Digital conversion) via Onkyo 706
Discussion in 'AV Receivers & Amplifiers' started by samraj, Feb 8, 2009.
Tags:
  1. samraj
    samraj
    Mar 25, 2004
    44
    esex
    I've connected my Sky+ via digital convertor and feed component inputs to the amplifier. I am having problems as the screen keeps changing the aspect ratio and screen keeps going blank very irritatingly- Sony 40W4500 . Pls advice if I should change the way I connect to the amp or if changing setting should help. I've also just placed an order for the SKY HD box which I won't be getting for atleast 3 months.
  2. chilipepper195
    chilipepper195
    Jun 11, 2005
    113
    +8
    Is this only when you change channel/when the programming on a certain channel changes or does it just happen completely randomly while watching something?
    Go into the HDMI Menu (Hardware Setup > HDMI) and set the Output Resolution to Through and set the Zoom Mode to Normal. If they are already set as this or the problem continues go into the Sky menu and go to System Setup > Picture Settings and make sure its set to 16:9 and also make sure your TV hasn't got automatic aspect ratio turned on.
    If the problem still continues are there any other inputs still having this problem and, if so, how are they connected?
    Also, what exactly do you mean by its connected using a 'digital converter' - is that just the audio?
  3. Grangey.
    Grangey.
    Apr 24, 2006
    5,779
    Oxfordshire
    +886
    you're not achieving anything by having your sky video through your amp unless you're using the amp as a switcher. If you can put sky directly to the tv I would say do that. Otherwise as above, change your HDMI setting to Through
  4. jet3d
    jet3d
    Jun 13, 2006
    261
    +20
    do i take you are using something to convert the s-video to to component (red, green and blue rca)?
    or do you mean you are using 'composite' (red, white and yellow rca)...
    if using composite try s-video direct to amp instead
  5. samraj
    samraj
    Mar 25, 2004
    44
    esex
    Yes I am using (CSY-2100 / SCART to Y-U-V Converter) - it upconverts the RGB out of SKY+ for the component inputs. I was using this convertor to feed my old plasma which didn't have the scart inputs. I would like to use the amp as my switcher.
  6. chilipepper195
    chilipepper195
    Jun 11, 2005
    113
    +8
    You don't need a converter box. The Onkyo should do that for you. Just plug it in directly to the Sky box using composite cables or S-video from the amp. You can then attach component or S-video cables from the amp to the TV and output it through that or just use an HDMI. It might not look too great through HDMI as it will highlight the poor quality of composite cables but if its only temporary until you get Sky HD you might be able to live with it.
