Sky Digital and high winds
Discussion in 'Sky Digital TV Forum' started by RMCF, Feb 21, 2002.
  1. RMCF
    RMCF
    Aug 24, 2000
    7,567
    +785
    We have been having some fairly strong winds over the last few days and I noticed that I am getting artefacting and lip sync problems with my picture when there is a gust. Is this common to minidishs or does mine need tightened?
  2. paiger
    paiger
    Depends how exposed it is to gusts. It may need tightening but I doubt it, it's probably just in a place where the wind hits it. Ha ve a look around and see if there is a better place for it.
  3. Orbitalzone
    Orbitalzone
    Feb 23, 2002
    394
    E.Sussex
    +43
    It could be your dish is being moved by the wind, or maybe if it's mounted on a tallish pole, the pole is flexing under the wind. Other things, like a big tree being blown could interfere if it gets blown across where the dish is looking at.
  4. delta
    delta
    Oct 16, 2000
    469
    16
    North East Cheshire
    Me too, but not just the wind, the rain frequently causes loss of signal, something that never happens on ITV Digital.
  5. Neil69
    Neil69
    Jun 8, 2001
    316
    2
    13
    Leigh
    +17
    I've had problems with Sky News when it was very windy, the picture kept freezing. It was just like a dirty DVD. Everything's OK now the wind's died down.
    Neil
    :cool: :cool: :cool: :cool:
  6. RMCF
    RMCF
    Aug 24, 2000
    7,567
    +785
    I have never had a problem with rain, no matter how heavy. Its just this week with the wind, but admittedly it is damn strong!! I spoke to my installer and he assures me that it is as tight as it'll go. He says that if it shakes by 1cm it will cause the picture to go. Mine is on the back wall of my house about 15ft up. And there are no houses around - nothing to break up the wind. Ah well, it not that often we get winds like that. Just one of the limitations of satellite TV.
  7. paiger
    paiger
    Yep, it's a great platform but you can't do the impossible and 99% of the time we don't have weather like that. I must say that my dish is sheltered so never gets affected by gales.
  8. Andrew_arkless
    Andrew_arkless
    Sep 19, 2001
    181
    Essex
    +6
    A had a few problems (with rain) about 3 or so break ups within a month, I got sky back out and he found that the original installer had made a bodge of putting the plug onto the cable from the dish, he changed the plug & it upped the single strength by a small amount - since then ive only had 1 weather problem in 15months. It may be worth checking out.
