sky digibox with 2 rgb scarts?
Discussion in 'Sky Digital TV Forum' started by steveho, Aug 29, 2004.
  1. steveho
    steveho
    Apr 21, 2004
    165
    +3
    Can anybody recommend a good sky digibox that has two rgb equipped scart sockets that i can feed into a tv & dvd recorder?
    thanks steve
  2. cinesom
    cinesom
    Aug 30, 2004
    30
    Buy from Scancom UK (www.scancom.ltd.uk) one active scart splitter, set main output of your Sky to RGB and feed it into this, you now have two RGB's out. 60 or 70 quid
  3. skiller
    skiller
    Nov 8, 2003
    4
    Why do you need 2 RGB scart outputs?
    Any decent DVD recorder will provide RGB passthru so you just plug the one Sky RGB out into the DVDR, then the DVDR goes into your telly.
    Or have I missed something? :rolleyes:
  4. steveho
    steveho
    Apr 21, 2004
    165
    +3
    SKILLER,
    On the digibox the scart that goes direct to the tv is rgb,the scart that goes to the dvd recorder is non rgb
  5. skiller
    skiller
    Nov 8, 2003
    4
    I know the digibox has 1 rgb and 1 non-rgb scart.
    The point I am trying to make is that the DVD recorder should be between the Sky box and the tv.
    RGB out from the Sky box goes into the DVDR. And then daisychain the DVDR into the TV.
