SKY digibox to projector
Discussion in 'Cables & Switches' started by Oldgold, Mar 20, 2005.
  1. Oldgold
    Oldgold
    Feb 16, 2005
    172
    +4
    Can someone please tell me which would provide the best picture quality in connecting a sky digibox to a projector (such as the panny ae700)?
    RGB scart to RGB scart
    or RGB scart to component (via one of those converter boxes, such as the Keene Syncblaster one)
    Or s-video to s-video.
    Also, is there anything that could convert the digibox signal (or DVD non progressive output) to a progressive scan component input - or is this not possible?
    Many thanks
  2. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    Keene do several boxes which will convert to progressive scan from a range of inputs, but to get good results you need to spend quite a lot on the box. S-video to s-video is quite a cheap connection method and can yield some fairly good results. I suggest you try that first, before buying converter boxes.
