Sky Digibox Scart conectivity
Discussion in 'Sky Digital TV Forum' started by drunkenmaster, Feb 8, 2005.
  1. drunkenmaster
    drunkenmaster
    Jan 19, 2005
    1,567
    The Shaolin Temple
    +44
    I have a pace digibox not the Skyplus version and a pana 36pd30
    **Bog standard 21 pin connected scart vs high quality scart.**
    Does the higher quality scart offer an improved performance over the bog standard? As it seems the signal output from the digibox is not of high quality
    I've been searching the forums including the cabling posts but no joy!!
  2. nig28
    nig28
    My answer is, yes it can, but it depends how poor the scart is to start with, and it is very marginal.
    On your sky settings menu you should be able to see the difference between PAL and RGB, but maybe not different leads, unless you are having problems.
    Nigel
