Sky Digibox S-video
Discussion in 'Sky Digital TV Forum' started by Greg Hook, Aug 11, 2003.
  1. Greg Hook
    Greg Hook
    Moderator & Reviewer
    Nov 25, 2001
    22,628
    2
    In a secret location with Jennifer Lawrence
    +9,348
    Just got the excellent ProV+ and although it accepts my scart to three connecters I would really like to use the S-video instead.
    But I have a Panasonic Digibox with no S-video output. Browsing the net I noticed a Grunding GDS3000 which does have an s-video output.
    Is it worth changing from my Panasonic DSB30 to this Grunding GDS3000 just for s-video. Is anything else better such as picture, menu speed etc.
    Greg
  2. hornydragon
    hornydragon
    Dec 19, 2001
    28,346
    +1,218
    Sky+ has S-video but the grundigs are highly sort after for the S-vid output there is one other Grundig box that has S-video out
  3. Fernsehman
    Fernsehman
    In addition to the GDS2000 and GDS3000, all Grundig GDS models ending in "/2" have S-video. The model number is on the label underneath.
    Fman
  4. pavlo
    pavlo
    It's probably worth checking to see if the scart output encompasses and s-video. My TV only has an s-video socket on the front for a cam connection, but one of the 3 scarts has an s-video line in.
    Paul
  5. twarde
    twarde
    Oct 11, 2002
    161
    2
    +24
    The Svideo on the Grundigs is not on the scarts, its on a 4 pin mini din socket. You can buy a scart converter block that will accept 2 audio phonos, a composite phono and Svideo mini din plug at most online cable suppliers or ebay,
  6. DaveP
    DaveP
    I had the opportunity to compare these two side by side and I have to say that, IMHO, the Panasonic wins hands down. The picture is better and the EPG faster.
    I would suggest you buy an RGB to S-Video converter and keep your existing box. You may get one secondhand for about £30-£35 on this or other forums, try a "want ad"!
    DaveP
  7. Greg Hook
    Greg Hook
    Nov 25, 2001
    22,628
    2
    +9,348
    Thanks for that DaveP
    I definitely don't want a slower epg. Especially as I am a big channel hopper!
    Will keep an eye out for one of these rgb - svideo convertors.
    Greg
  8. KO.NET
    KO.NET
    here ya go : http://www.rgbtosvideo.com/
  9. surrey lad
    surrey lad
    Dec 14, 2002
    718
    Kingswood, Surrey
    +29
    I found that my Pace STB RGB converted to s-video with the said converter, the image was too soft and the menus had a waving effect. Bought myself a GDS 3000 new on Ebay for £120:cool: and the waving effect is curred and the picture is alot more solid and sharper.
    BTW, this is connected to my HCPC-dscaler4.17, sent to my Cine 7 and viewed on a 7ft screen. At that size every change to pq is noticeable.
    surrey lad ;)
