Sky Digibox Problem
Discussion in 'Sky Digital TV Forum' started by kennydies, Jun 14, 2001.
  1. kennydies
    kennydies
    May 7, 2001
    191
    UK
    +4
    My friend recently upgraded to sky digital and after playing I discovered that when she pressed the sky button on the control her Sony TV toggles between each AV channel. It is nothing to do with the scart, the Sky control phsically turns her TV over with IR codes from her controler.
    Has anyone else discovered this? If so is there a way around it, save covering the IR sensor on her TV?
