Sky Digibox and Magic Eye
Discussion in 'Sky Digital TV Forum' started by gizmogadgetgirl, Mar 10, 2002.
  1. gizmogadgetgirl
    gizmogadgetgirl
    Mar 10, 2002
    16
    4
    Super Swinton
    I have sky digibox in one room and magic eye in another so satellite can be watched in two rooms. Recently I purchased a Toshiba 36ZP18P which is in the room with the magic eye. The picture is not as sharp as with the previous tv (21"). It is my intention to change round the satellite connections. I would just like clarification that moving the digibox to the toshiba would produce a clearer picture. I know it probably sounds pretty obvious but would appreciate the response from knowledgeable folks before I get someone in to do this. As you may have guessed I am a bit of a novice at this type of thing. Cheers, Linda:blush:
  2. bob007
    bob007
    Always best to have the digibox connected to the main TV you are viewing, to guarantee best possible picture, especially if it's a 36" set. Would think it safe to say if you have the digibox relocated your picture quality will improve.
  3. gizmogadgetgirl
    gizmogadgetgirl
    Mar 10, 2002
    16
    4
    Super Swinton
    Thanks Bob, thought so!:)
  4. Nick23
    Nick23
    Feb 25, 2002
    121
    16
    Why not try moving the 36" TV to the digi box first to see if it improves the picture. Doing that would be much easier than moving the STB to the TV. At least that way you don't have to mess about with the $ky cabling.
  5. DaveP
    DaveP
    I'm not familiar with the Magic Eye device but most devices of this type only transmit Composite Video which is the poorest of the video options used.
    When you connect the Digibox to the 36" TV make sure you use a good quality Scart lead and set the Video Output to RGB from the Sky setup menu. Also ensure Scart Control is set to on.
    DaveP
  6. alanrob
    alanrob
    May 24, 2001
    2,375
    63
    Glasgow
    +234
    The Remote Eye connection from you Sky box is via an RF connection so the picture is only as good as your tuner on your TV and the cable used to carry the signal.
    Best to have the main TV plugged via scart from the digibox and use the second TV via the remote eye.
    I'm using two in my house for the bedrooms and the picture is very good in both, but nowhere near as good as the main TV via and RGB scart :)
