SKY Digibox and Humax HD Freesat running off same cable
Discussion in 'Sky Digital TV Forum' started by mayroad, Feb 11, 2009.
  1. mayroad
    mayroad
    Feb 11, 2009
    3
    I already have a Humax HD Freesat box linked up to a dish via a single cable. I am getting a standard SKY Digibox so I can watch sports etc. - can I run both receivers off the same cable from the dish and if so what kit do I need to split the feed. I want to keep the HD box to watch the odd bit of BBC HD and I did not want to pay for SKY HD.
  2. Chris Muriel
    Chris Muriel
    Jun 14, 2002
    7,280
    Manchester
    +763
    By the far the easiest solution would be to replace your existing LNB with a quad one and run 2, 3 or 4 cables from the existing dish.
    Chris Muriel, Manchester
  3. mayroad
    mayroad
    Feb 11, 2009
    3
    Thanks for the reply - really wanted to avoid that if possible as we live in an old house on a hill side, and it's a 50 metre cable run up to the dish - don't really want to run another cable for aesthetic reasons. I should also say we don't expect to use the SKY and Freesat box at the same time - it will always be one or the other.
    Is there any other solution.
  4. steford
    steford
    Mar 7, 2004
    1,238
    48
    Ealing
    +62
    Does the Freesat box have an LNB out/thru connection? You could go from that into the Sky box if so. Only issue would be that there will be a conflict if both boxes are on and require a different polarity transponder (one wants vertical, one wants horizontal). If you never need them on together or permanently (PVR) then this is not an issue.
    EDIT: Had a quick look round and the only Humax Freesat HD receiver I could see doesn't have the LNB Out connection. You could use a manual switch like this maybe
    http://www.maplin.co.uk/Module.aspx?ModuleNo=17808
    No idea if it's any good though. You might also find an auto switching solution here.
    http://www.satcure.co.uk/accs/page1b.htm#sps1
    Depending on your signal the loss in quality may not be acceptable with these devices.
  5. saabtech
    saabtech
    May 26, 2006
    285
    28
    Lybster
    +27
    I have a technisat lnb feed splitter that i do not use anymore, this would do the job. If you want it pm me your address and i will send it to you gratis,
    Regards, Saabtech.
  6. mayroad
    mayroad
    Feb 11, 2009
    3
    Thanks very much everyone for your help
  7. the_gavnor
    the_gavnor
    Mar 2, 2007
    207
    Worthing, West Sussex
    +21
    You can't split an LNB feed, as the LNB will be switched to one polarity, but then if you try watching a channel on the other box on another polarity you will lose signal on one of the boxes
  8. saabtech
    saabtech
    May 26, 2006
    285
    28
    Lybster
    +27
    The splitter in question works the same way as a lnb loopthrough, you can watch one or the other, or both at the same time provided they are both of the same polarity.
    I first used this switch on a Sakura and a Finlux reciever, [both had only 16 channels], with a hand cranked movable dish.
    It still works, I checked it last night.
    Anyone else remember Super Channel, Fallan decoders and sky when it was free to air?
  9. po_man
    po_man
    Dec 23, 2004
    1,712
    St Albans
    +63
    Hello there,
    Apologies if this is deemed as "hijacking" a thread but I have a quick question. I have Sky+ and have been thinking of getting a separate FreeSat HD box for, obviously, the free HD content.
    Can anyone advise how easy it would be to achieve this? I mean, how hard would it be to fit a quad LNB. Is this something I could do myself or would I need to get an engineer in.
    Also, is it just a question of then plugging the cable in to the the FreeSat box to get the HD channels?
    Many thanks in advance
  10. naes12
    naes12
    Feb 27, 2009
    48
    Hello, i currenlty have standard sky but i am uprading to Sky HD :clap:. I am also buying a new TV with freesat. If i get Sky HD installed, will the freesat run off the Sky dish and sky cable? Once the sky in plugged into the back of the TV will freesat start working straight away?:rolleyes:
