Sky Dig, Tivo, Scart To YUV and PMA400E
Discussion in 'Plasma TVs' started by mutation, Aug 15, 2003.
  1. mutation
    mutation
    I have an ickle problem since i rewired up my system and changed a couple of settings.
    I changed the output on my sky to rgb as suggested but when run through my tivo, and then my tivo running to the yuv converter i just got a blank screen on the plasma (it seemed it was sync-ing though, and i didnt get a no sync signal)
    I changed the output on sky to pal
    then the input on tivo to pal, then the output of tivo to pal and rgb, i still cant get a picture (im using a maplins converter box at tghe moment but am going to get a js technologys one)
    i've tried all possibly combinations but still no picture (or a blank screen) could this be the converter?
    i've checked tivo in my bedroom on my normal tele and i do get a picture.
    anyone have any ideas ???
    thanks as always
  2. peter350
    peter350
    Apr 22, 2002
    301
    Preston, Lancs
    +11
    I forget the exact menu options but on the tivo and on the sky box you need to turn on scart control/ tv control or whatever they call it. You'll see what I mean in the menus where you can set rgb/pal.
    This should cure your problem.
    Regards Peter
  3. mutation
    mutation
    thanks peter
