Sky+ Died Please Help!!!
Discussion in 'Sky Digital TV Forum' started by JiMbOb_74, Sep 20, 2004.
  1. JiMbOb_74
    JiMbOb_74
    Help! My sky+ box has just decided to die.
    Earlier this evening while watching my star wars dvds :thumbsup: i noticed the sky box was making some strange noises...a bit like the fan was catching slightly.didnt thing anything of it as was working and watched a bit of tv...
    That was until i pressed the sky+ button... it did the usual crash black screen....
    Unplugged for 60 seconds...replugged in... and now every minute or so it makes two sort of grinding noises and stops then does it again and again ...
    I have a feeling the drive has died. The box is only about 1 1/2 years old but is has had a hard life (girlfriend watches all the soaps!)
    Any help would be great.If the drive has gone how do I put in a bigger one
  2. drummerjohn
    drummerjohn
    Sep 2, 2001
    2,497
    South Derbyshire
    +205
    Sounds like your hard drive has died.
    Go out and buy yourself a 120gb HD and put that in. Take out the old Maxtor and check the serial on Maxtors website to see if its under warranty. If it is send it back and they will post you a new one.
  3. JiMbOb_74
    JiMbOb_74
    Thanks.... Have ordered a maxtor 120gb... In the mean time got the sky+ working with an old 20gb drive..It doesnt recorde but atleast I have a picture (I am using my sky+ as a tv tuner for my pana 42"plasma..
    Once I have the new drive how do i format it etc?
  4. JiMbOb_74
    JiMbOb_74
    update...it does record now! but with only 20gb not much room.!
    Its an old seagate aswell...
  5. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    to format a new drive, all you do is go into the engineers menu and do a full system reset, this formats the drive for sky+
    see here for more info
