SKY+ & Denon 2105
Discussion in 'AV Receivers & Amplifiers' started by Rick1486, Feb 24, 2005.
Tags:
  1. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Hi gang - got the sky+ installed today :clap: and my question is this.
    Previously with our old sky box I had audio connected via analog left/right phono into the 2105. The installer copied this with the new box, but I know that with sky+ we have an optical output also.
    I've connected a toslink/toslink between sky+ & the 2105 and performed the setup in sound settings. Do I now need to remove the 2 x audio cables and just run optical out or should I leave them and give myself the option of both analog and optical input via the 2105?
    Rick
  2. Jase
    Jase
    Mar 16, 2001
    10,956
    United Kingdom
    +3,417
    You only need the optical cable, although there won't be a problem leaving them both connected. The Denon will take the digital signal as priority over the analogue one if it's left on AUTO. :)
  3. Rick1486
    Rick1486
    Feb 22, 2003
    573
    16
    Oxfordshire
    Cheers mate.
    Rick
