Sky+ DD sound
Discussion in 'Sky Digital TV Forum' started by Peter J Roberts, Jan 12, 2004.
  1. Peter J Roberts
    Peter J Roberts
    Apr 4, 2001
    102
    Near Abington
    When are Sky going to sort out the DD sound on channels 301/303?
    Im getting fed up with having to turn the dd sound off in order to hear anything.
    When I first had Sky+ I phoned Sky to complain and was told it was an Intermitant fault and they did'nt know what chased it?
    Appanently it done not affect all the Sky+ boxes at the same time. Go Figure
  2. wozwebs
    wozwebs
    Jul 10, 2003
    1,196
    +111
    Noticed on About A Boy lasty night that it was working but very quiet. Had to turn the volume on my amp really high.
  3. Peter J Roberts
    Peter J Roberts
    Apr 4, 2001
    102
    Near Abington
    I've Now switched off my Sky+ on the wall and I once again have sound. Go Figure
  4. Attu
    Attu
    Jun 16, 2003
    809
    28
    +42
    Strange, I havnt had any problems with mine since Christmas.
    Andy
  5. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    I was under the impression the problems had for the most part been solved with the December OS update, the threads in the DS forum has certainly gone cold after being very active.
  6. Peter J Roberts
    Peter J Roberts
    Apr 4, 2001
    102
    Near Abington
    My Sky+ Is New only fitted in late Dec How do I force a software Update to hopefully cure this continuing problem.
  7. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    This is the procedure, of course like all things you do it at your own risk:)
    Hold the backup button down on the box while turn the power off at the wall socket.
    Wait 10 seconds and then turn the power back on WHILE STILL HOLDING DOWN THE BUTTON and then wait for a message on the screen or all 3 lights on the front of the box to light up, then release the button. You will only see this message if the SKY+ is connected via scart and the TV is on ( obvious I know ).
    The new software will take around 10 minutes to download and then the box will reset it self and stay in standby, wait another couple of minutes then turn it on with remote or the button on the box and you should be away.
