sky+ DD hook-up
Discussion in 'Sky Digital TV Forum' started by rats, Dec 1, 2003.
  1. rats
    rats
    Hi people. I`ve recently had sky+ installed, (no complaints as yet) and was wondering if I can connect it to my sony str-db930 receiver to get the benefit of dolby digital sound, and which is the best way to connect, as there are a couple of spare optical connectors.? :confused:
  2. scarty16
    scarty16
    Jul 1, 2003
    1,406
    +304
    the sky + box has an optical output, connect it up to the optical input of teh sony and go into the menu of teh sky box and change it over to dolby digital.
    you need movies of disney channel to test whether it is working correctly though
  3. rats
    rats
    Hi scarty, which is the best optical connection on the receiver to hook up to, or can you use any. ??
  4. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Use either.
  5. Techno
    Techno
    Nov 20, 2003
    312
    Does the SKY+ only have optical output?
    I have 1 x Optical and 1 x Coax, I'm using the Optical for my DVD player connection and was hoping sky would have Digital Coax output.
  6. Noodle
    Noodle
    Jan 6, 2003
    577
    Peterborough
    Yes indeedy, but you can buy an optical > coax convertor.
  7. Techno
    Techno
    Nov 20, 2003
    312
    That's alright then.
    Thanks for quick reply mate.
  8. MarkR
    MarkR
    May 3, 2003
    1,900
    Somewhere in Kent
    +344
    Also rats you may as well use an S-video lead to connect from your receiver to your Sony, thats if you haven't already!! At least then it will improve your picture as well.:)
