Sky+ Daisy Chain
Discussion in 'Sky Digital TV Forum' started by bluetone, Sep 17, 2001.
  1. bluetone
    bluetone
    Jul 1, 2001
    10
    england
    Can anyone enlighten me as to how the outputs on the new Sky+ box works?
    I have a JVC S-VHS VCR and on our normal sky box, we connect the receivers video out to the VCR's video in and then connect the VCR to the TV.
    Thing is, when i want to archive whats on the Sky+ hard drive to my VCR, does that mean i won't be able to view whats on Sky at the time because theres only one scart coming from the Sky+ box to the VCR.
    My tv only has two scarts and one of them is occupied with a DVD, so daisy chaining the vcr and Sky+ is necessary.
    thanks for any help you can give.
  2. Jon Baker
    Jon Baker
    Jul 22, 2001
    48
    Cumbria
    Basically the two scarts work as before. To get an S-VHS connection to your videoe you must plug into the 5 pin S-VHS socket on the + box and use the audio phonos to furnish the sound to the video.<br />I don't loop the DVD through the digibox, but use a fully wired scart switch box which is less than £20 from <a href="http://www.lektropacks.co.uk" target="_blank">www.lektropacks.co.uk</a> (get the scart data switch box in cream as the fancy black ones aren't fully wired).
  3. Jon Baker
    Jon Baker
    Jul 22, 2001
    48
    Cumbria
    PS
    The sky+ manual talks about archiving at night, so I presume that you lose our record functionality while archiving is being performed.
