Sky + cutting off the end of programs
PaulaB
I have a new sky + box that has one 3 occasions cutthe end of programs off. The program is Silent witness can someone give a solution or is it the box doesn't like that program?
JimmyCobra
only had sky for a few days
but you can pad the recordings in sky+ setup ie add extra time to the end of the timer
Starburst
The SKY+ obeys the EPG and if a broadcaster doesn't follow their own published listings data then SKY+ can only start/stop as it's been told.
You can as JimmyCobra says add some padding to both the start and/or stop times (upto 10 minutes) or use the AUTO setting which for me has proven to be 99.9% effective.
Dan2234
Even adding 10mins at the end sometimes doesn't work on ITV so the best bet is doing a Manaul Recording.
