Sky + copy to vhs ability
Discussion in 'Sky Digital TV Forum' started by malcom, Sep 12, 2001.
  1. malcom
    malcom
    Aug 25, 2001
    526
    +4
    Forgive my ignorance about Sky+ but I understand that sky+ has a copy (button)to archive material from the Sky+ hard drive to a vhs recorder.
    I am puzzled! Why does it need a separate copy function (button)
    Is it not possible to locate the item to be transferred to vhs and simply press the play button on sky+ along with the record button on the vcr that is connected via the usual scart connectors. Why does it need a copy (button). Am I missing something?
  2. squid
    squid
    Feb 26, 2001
    546
    19
    the big uk
    it probably outputs the channel it is on through the video scart unless you press this button (so you can watch somthing you have recorde while you tape somthing with the vid and tape somthing else with the inbuilt recorder
