Sky+ copy function
Discussion in 'Sky Digital TV Forum' started by Neil69, Jan 2, 2002.
  1. Neil69
    Neil69
    Jun 8, 2001
    316
    10
    Leigh
    +17
    Erm...when using the copy function on Sky+, nothing happens. My digibox is connected to my VCR via scart on input AV2. I selected which programme I wanted to download to tape but my video doesn't recieve anything. I can't find my instruction manual, HELP!!! please before I get mad & throw it out of the window (NOT) !!!
    Cheers, Neil
    :mad: :mad: :mad:
  2. Starburst
    Starburst
    Jul 13, 2000
    17,846
    Ilkeston
    +975
    Can you watch the normal SKY+ output which is sent to the VCR through scart and then onto the TV ?
    Have you got the scart plugged into the correct sockets on both SKY+ and the VCR?
    Is your scart cable wired up for one way, they were common many years back.
    Have you ever used your VCR to tape a satellite channel before using SKY+?
  3. Neil69
    Neil69
    Jun 8, 2001
    316
    10
    Leigh
    +17
    Yes for questions 1,2,4. No for question 3.
    My scart lead maybe just one way. I'll swap it round & post another reply.
    Cheers mate, Neil
    :mad: :mad: :mad:
  4. museumsteve
    museumsteve
    Jan 28, 2001
    7,979
    4
    Nth Hampshire
    +1,094
    Hi Neil..
    I'm probably being stupid, but once you have selected the programme with the Red COPY button..did you then press Play or Select on Sky+ remote..
    I only ask 'cos my missus has just done the same thing and because the screen showed the programme as Copy, she assumed that was it, it's only on checking the manual that we found you have to press the Play or Select button after you have pressed Copy button (but after you have started recording on VCR)..
    Sorry it sounds long-winded..but it worked perfectly..
  5. Neil69
    Neil69
    Jun 8, 2001
    316
    10
    Leigh
    +17
    Hi to you who have replied to me regarding my little problem.
    My scart lead was the problem as it was only one way. I have now swapped it around & now everything is hunkie dorie & works fine.
    Cheers, Neil.:D :D :D :D
  6. Diane
    Diane
    Is there some way you can use a sky+ box to get at both live feeds, one for watching on another telly? If you're recording and watching paused TV at the same time which I believe is possible, can you get both feeds?
    Diane Maddox
  7. Neil69
    Neil69
    Jun 8, 2001
    316
    10
    Leigh
    +17
    I don't believe that you can have 2 TV feeds from the Sky+ box as it only has 1 TV output from 1 of the tuners. Tuner No. 2 is for recording only. If you could get two feeds at once no one would take up the 2nd digibox & subs for 12 quid.
    Cheers, Neil
    :cool: :cool: :cool: :cool:
  8. Diane
    Diane
    Which wouldn't be a bad thing:) It seems that no matter which way you turn, Sky is trying to rip you off. I know that new subscriber cost a lot at first but there is also the economy of scale to consider. In all the time Sky has been going not once have their subscribers benefited from the large increase in viewers they've been getting. In any other market in would of happened but then that's what happens when you have a virtual monopoly and a government prepared to do nothing. And as for the £10 a month for Sky+, Duh?
    Rant over, sorry
    Diane
