Sky+ Copy Function Crash
Discussion in 'Sky Digital TV Forum' started by thedoc, Aug 20, 2004.
  1. thedoc
    thedoc
    Aug 22, 2003
    262
    16
    Sorry if this has been covered here or elsewhere (I did look but cannot find reference to it) ...
    Since the recent update I have found when I came to use the copy function the other day it goes as far as letting me press select to start Sky+ playing the selected programs, and then it pauses and flicks straight back to the main planner page... If I persevere, once or twice I've got it to run, but once it reaches the end of the first program, it pauses until backup is pressed.
    Using Pace Sky+ V1 (April 03). Disk is running fine, no other issues or bugs noted, disc is original 40GB at the moment, but have new 120GB 5400rpm FDB Maxtor waiting to go in when I empty this disc ! :)
    Anyone else with this issue ?
  2. Starburst
    Starburst
    Jul 13, 2000
    17,842
    Ilkeston
    +975
    Never had any problem with the COPY system myself but other have certainly reported similar problems to what you are experiencing, mostly with v2's though.
    A reboot or OS reload might fix the problem, it would be reasonable to assume it's a software issue and not some external influence.
  3. thedoc
    thedoc
    Aug 22, 2003
    262
    16
    Thanks - at least I'm not alone !
