sky+ cooling fan
Discussion in 'Sky Digital TV Forum' started by bop, Aug 24, 2003.
  1. bop
    bop
    can anyone tell me if the internal cooling fan on my sky+ digibox is supposed to be on all the time or just if it gets hot.
  2. Starburst
    Starburst
    Jul 13, 2000
    17,838
    Ilkeston
    +979
    The fan is temperature sensitive so should only come on when the internal temp is too high, if it's running all the time then either the box is runing too hot due to a fault or it's local enviroment or the fan itself is faulty.
  3. bop
    bop
    thanks for that , only just had the box and when the guy installed it the fan was running all the time. I had to switch the box off at the mains and when i reconnected it i noticed the fan wasn't going. but that has put my mind at rest a bit..
