Sky+ control SR5400 Marantz
Discussion in 'Home Cinema Control & Remote Controls' started by glebecs, Sep 1, 2005.
  1. glebecs
    glebecs
    Hello, when I bought my Marantz SR5400 a couple of years back I managed to get the Sky+ remote to control the volume (while in Sky mode not TV mode), I recently went away for a couple of weeks and it seems the cat-sitter dropped the remote and left the batteries out etc, I cannot find how I set the control up, anyone know?
    Thank you
  2. sven_sol
    sven_sol
    Jun 5, 2005
    20
    4
    Royston
    I've got the 5200, so you could try looking on here..
    http://www.remotecentral.com/
    Usually have everything on there you need, Graphics, Code, Layouts etc.
    Easiest just to use the software that came with it and save the image, that way if the remote ever gets wiped for some reason you can just reflash it.
