Sky+constant recording??/
Discussion in 'Sky Digital TV Forum' started by p.booth, Oct 17, 2003.
  1. p.booth
    p.booth
    Oct 8, 2002
    4,048
    mbro
    +151
    Just had SKY+ installed yesterday. I`ve read some where that you can enable" constant recording" in the services menu. Ive got ver1.3.ob9 and I don`t see the option in services menu. Any ideas ,please????
  2. chic
    chic
    Jul 1, 2001
    5,985
    glasgow
    +871
    you can set up the box to constantly record up to 60 mins of a programme this feature is called instand rewind so the box is always recording a buffer of up to 1 hour of a programe so if you want to see something again you can rewind it to set it up do the following:-
    select sky+set up on the service menu,select instant rewind and select how much you want to set it for then make sure you save before you exit.
    one think to note this only records to the buffer part of the hard disc it doesnt save it into your planner so if you change channels you will loss what has been recorded
  3. p.booth
    p.booth
    Oct 8, 2002
    4,048
    mbro
    +151
    Tried that but forgot to save settings . now working since saving settings again . Thanks .
