SKY+ connections
Discussion in 'Sky Digital TV Forum' started by BTMAN, May 12, 2005.
  1. BTMAN
    BTMAN
    :lease: I've recently had sky+ installed in a new home and the electricians wired throughout the house so I can watch it in virtually every room. Although it was working in these other rooms on the day it was installed, and for a short period afterwards, it has since stopped sending a signal other than to my main TV located beside the sky+ box. All other terrestrial channels are being despatched into the roofspace to my splitter box and are ok on the "other" points but sky+ is gone. Have I touched a button somewhere or can anyone shed some light as to what may have happened?
    BT
  2. derbyjj
    derbyjj
    Feb 16, 2005
    238
    Rainhill
    +19
    check that you are getting a signal from the rfout 2 and rfout 1. you may have changed the rf frequency that the sky box outputs to these sockets by mistake. its in the hidden menu.
  3. Nick_UK
    Nick_UK
    Nov 13, 2004
    9,748
    103
    +270
    To get to the hidden menu, press
    Services >> 4, 0, 1, Select
    by the way :)
  4. BTMAN
    BTMAN
    Thanks u guys, i checked that and that's not the problem either. SKY engineer coming on monday after 15 minute telephone call and doing everything again with their engineer. It sounds like the rf output in the decoder is gone. :nono:
    BT
