Sky+ connections
Discussion in 'Sky Digital TV Forum' started by Brianjhussey, Nov 15, 2004.
  1. Brianjhussey
    Brianjhussey
    Feb 15, 2002
    242
    Somerset
    +9
    After months and months of indecision I have been lured by Sky+160 and the special offer of £299 and free installation.
    I am expecting delivery this afternoon and, in preparation, have disconnected my VCR and Nokia digital receiver. All that will remain, for now, will be my DVD player and the SKY box.
    The DVD player is a Toshiba 520 connected via component leads to a 56" Toshiba RPTV.
    How do I ensure the best possible reception, connection wise?
    It should be perfectly straight forward but any advice or tips will be gratefully received.
    Many thanks, Brian.
  2. johndon
    johndon
    Feb 3, 2002
    1,975
    63
    +108
    Best connection from the Sky+ box is RGB scart. Just make sure you set it to RGB in the settings menu. I think the AV1 scart on the Tosh is RGB.
    HTH
    John
  3. Blu Ray
    Blu Ray
    Jun 14, 2004
    496
    Chorley, Lancs
    +12
    Either a straight (good) Scart to Scart, or Scart - VGA via a JS convertor. I'm unsure what connections your RPTV has.
  4. Brianjhussey
    Brianjhussey
    Feb 15, 2002
    242
    Somerset
    +9
    John,
    Thank you for your response. It's just as I thought. You're correct about the Tosh RGB scart.
    Blu Ray,
    Thank you also, although I have no idea what vga or JS convertors are !
    Brian.
