sky+ connection to optoma rd50
Discussion in 'Cables & Switches' started by BIGGUSDIKKUS, Dec 10, 2004.
  1. BIGGUSDIKKUS
    BIGGUSDIKKUS
    please can anyone tell me the best way to connect my optoma up to the sky box and what leads to use the box is an amstrad
  2. Dutch
    Dutch
    Dec 5, 2002
    2,601
    2
    5
    North Yorkshire
    +284
    Hi BD,
    Set your Sky box to output RGB instead of PAL (composite), then connect to the Optoma with a fully wired Scart from a good make like QED or Ixos. Hope this helps.
    Steve
