SKY Communial Dish
Discussion in 'Sky Digital TV Forum' started by colinb07958, May 2, 2007.
  1. colinb07958
    colinb07958
    Nov 20, 2005
    915
    28
    +44
    I am looking to buy my first flat. Apparently there is a Sky Communial dish. As I know nothing about this does a communial dish restrict any options on Sky?
    Also with a Communial dish can I get the £26 for 3 deal? also what is the broadband service like on that?
  2. Chunder
    Chunder
    Oct 27, 2005
    593
    28
    +37
    The communal dish will only restrict you to the type of signal/service that was set up - usually just standard Sky.
    It is possible to get an upgrade to Sky+ or SkyHD, but this will affect all the other users of the same dish, and can be phenomenally expensive... :(
  3. sjj84
    sjj84
    Aug 7, 2006
    277
    28
    +24
    How old is the flat, some new ones will have 2 feeds per flat meaning you can have sky+, depends on the spec when they were built. Mine only has one feed and so can only have standard sky. As for the broadband, that is irrelevant to communial dish as it done through the phone line. The other thing is that sky won't do the install themselves, you have to go through a third party company which sky will put you into contact with.
  4. smallvillex
    smallvillex
    Mar 1, 2006
    432
    +14
    Hey fella,
    Best bet is to get in touch with the MDU team at Sky, just have your flat details to hand and let them do the rest....:smashin:
