Sky - Communal Dish Issue
Discussion in 'Satellite TV, Sky TV & FreeSat' started by chrisherd89, Mar 13, 2018.
  1. chrisherd89
    chrisherd89
    Mar 13, 2018
    4
    York
    I have recently moved into a flat and I know it has a communal dish. There is a single dish mounted on the side of the property with 6 or so satellite cables running down into a large plastic box - which I assume to be a distribution box to each of the flats. I do not know why wires simply don't run directly from the dish into each of the 3/4 flats directly. What's the need for this box? I have seen the direct method on nearby flats.
    I spoke to my letting agent and they informed me the management company needs to 'switch me on to the communal dish'.
    Now the crux of my question - in the flat there are only RF points. I have actually taken the wall plates off to check for any satellite points connected to the communal dish - there aren't any. So, what does this switch mean? Is it at all feasible that I will be able to receive sky via the RF point once 'switched'?
    I am confused as there definitely is a dish, and it's communal, but I cannot see how it comes in to the flat nor what this supposed switch is.
    Thanks in advance
    Chris
  2. logiciel
    logiciel
    Feb 2, 2008
    53,066
    UK
    +5,740
    It's possible but why not ask a neighbour or the agent?:rolleyes:
  3. chrisherd89
    chrisherd89
    Mar 13, 2018
    4
    York
    Just because the agent takes a long while to respond as he needs to speak to the landlord. Also, have asked the neighbours. No one pays for sky.
  4. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,599
    Oxford
    +1,334
    Sorry we are not psychic, more info required - there are several possibilities here.
    Is there only a single cable to the wallplates?
    How many wallplates in the flat?
    Do the wallplates have more than one output?
    Is the connector a Belling Lee (standard aerial plug) type?
    Is there a communal TV aerial?
    Have you connected it to the aerial input on your TV - if so what happened?
    Do the neighbours have Freesat or any other type of satellite reception?
    The switch is probably a multiswitch which is used to distribute the satellite signals and possibly also a terrestrial aerial signal down the same cabling as the satellite signal.
  5. chrisherd89
    chrisherd89
    Mar 13, 2018
    4
    York
    Thank you. There is only one cable to wall plates which are standard aerial and there is only one output. I did try to connect to the tv when I first moved in and nothing happened.
    I also tried to use an RF to sky converter via the sky box and this did nothing.
  6. davemurgatroyd2
    davemurgatroyd2
    Dec 26, 2004
    8,599
    Oxford
    +1,334
    What do you mean by this - is it a Belling Lee plug at one end and a F(screw on) connector at the other end of a cable?
  7. chrisherd89
    chrisherd89
    Mar 13, 2018
    4
    York
    That's exactly it
  8. TJT1
    TJT1
    Jul 29, 2011
    4,592
    East Sussex, UK
    +1,059
    That was an either/or question. Not a yes/no one.:facepalm:
  9. chrisherd89
    chrisherd89
    Mar 13, 2018
    4
    York
    Yes - it is belling lee at one end and F at the other.
    I have just checked and there is a digitial tv signal
  10. chrisherd89
    chrisherd89
    Mar 13, 2018
    4
    York
    Awesome - cheers
