SKY+ Code ror 42" PV500
Discussion in 'Plasma TVs Forum' started by Moncs, Jun 30, 2005.
  1. Moncs
    Moncs
    Jan 14, 2002
    460
    Edinburgh, Scotland
    Calle Sky yesterday to get a new code for my Sky+ remote control as the volume stopped working when I got my new PV500. The gut tried various codes but none worked.
    Doe's anyone know of the correct code?
  2. AV killed my CC
    AV killed my CC
    Jan 3, 2002
    41
    +3
    Standard panny one, which I think is 0051 worked fine. Info works as TV/AV button as well.
  3. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    185
    Have you also got your remote controlling your amp ? this will disable the voulme control function for the tv.
    Try pressing TV > Select + '2' together This will reset it back. The code I used was the third one in the list from the sky help page (i'm at work so can't check it)
    Go to Interactive > Sky help > FAQ > How do I control my TV.
    You get a alphabetical list, Pick P and then panasonic. Choose the first code of the modelnumbers that contain plasma codes (anything with a 42) The PV500 obv isn't included but this code will work.
  4. Sulis
    Sulis
    Mar 29, 2004
    574
    Bath
    On the SKY+ remote, press TV. Then point away from plasma and press SELECT and the RED button (at the same time) - the red led should blink twice. Then enter 678, then press SELECT - the red led should blink twice again. Then check that the SKY+ vol control now changes your PV500 volume. Then break into a hymn of thanks, and have a drink.
  5. stroppygoblin
    stroppygoblin
    Jun 2, 2005
    185
    678 - Thats the code, thanks Sulis.
    If after inputting this code, your volume control still doesn't work I recommend you try the 'AMP passthrough reset' described above.
  6. Moncs
    Moncs
    Jan 14, 2002
    460
    Edinburgh, Scotland
    Cheers guys, 678 worked a treat :thumbsup:
  7. tutu
    tutu
    Apr 28, 2004
    2,223
    48
    +58
    Thanks works on Sky Digital remote too :D
