Sky+ Code for Vision PM4230
Discussion in 'Plasma TVs Forum' started by Stella, Dec 3, 2004.
  1. Stella
    Stella
    Hi, I'm a newbie so be gentle with me! :blush: :hiya:
    Has anyone got any codes I can programme into my Sky+ Remote so it will operate a Vision PM4230 Plasma? The Vision codes on Sky do not work and Sky Tech Support are worse than useless! :mad:
    Thanks in advance and sorry if this is in the wrong Forum.
    Stella
  2. Stella
    Stella
    I've been told that a Company called Orion make Vision plasmas. Would the codes on Sky for Orion possible work for Vision?
  3. Stella
    Stella
    Anyone? :hiya:
  4. Stella
    Stella
    The answer is, "No." :mad:
  5. Stella
    Stella
    I've trawled the net and the only codes I can find are 0941, 065, 054 and 348 and none of them work. :mad:
    Anyone got anymore or am I talking to myself. :confused: :suicide:
    Stella
  6. absthechatter
    absthechatter
    Nov 27, 2004
    159
    Probably not right, but the codes I have for Vision are 113, 360 and 399. With 1061 and 1071 as brand numbers.
    Hope it helps.
    Abs
  7. Stella
    Stella
    Thanks for that but unfortunately they do not work.
    I might try an all in in remote. Kameleon? Do they have all the Sky+ functions?
    Stella
  8. Stella
    Stella
    For the record, the Kamelion will not operate the screen either. :mad:
    Chatty lot aren't you?! :laugh:
    Stella
