We're migrating the forum software to the next major version and this will require the site to be down for the best part of Monday 16th.
More details here. Apologies for the inconvenience.
Sky+ code for Tag AV
Discussion in 'AV Receivers & Amplifiers' started by memmerson, Oct 19, 2005.
Tags:
  1. memmerson
    memmerson
    Dec 12, 2002
    505
    Devon
    +16
    Hi all,
    I understand you can configure the Sky+ remote to control the volume on various AV amps. Does anyone know if there is a code for the Tag equipment?
    Cheers,
    Marc
  2. alexs2
    alexs2
    Nov 13, 2002
    13,967
    +1,672
  3. PhilB1234
    PhilB1234
    I asked Udo for this as a software development, but was told that the IR code systems used by the Tag are different to the Sky remote, so rather than it being different codes needed, they actually speak dfifferent languages so it can't be done....
    Have to stick with two remotes!
  4. memmerson
    memmerson
    Dec 12, 2002
    505
    Devon
    +16
    Thanks for the replies guys,
    sorry but I think I wasn't clear with my question. What I meant was that there are some 4 digit manufacturer codes that you can program into your sky+ remote that will
    reconfigure a few of the buttons to support various av functions. See the following site for a list of codes:
    http://web.archive.org/web/20041124013451/www.hummer.co.uk/remote-setup.htm
    I have tried the Audiolabs codes listed but they don't seem to work. Although as PhilB1234 said, if the IR languages are different then there probably isn't a Tag code anyway. Oh well, back to the drawing board!!
    Cheers guys
  5. PhilB1234
    PhilB1234
    That's what I thought you were meaning, but sadly, as described it can't be done.
    It's a shame as the Sky+ remote rarely leaves my hands some evenings!!!
  6. memmerson
    memmerson
    Dec 12, 2002
    505
    Devon
    +16
    Same here, it's a territorial thing with me. Anyone that makes a move for the remote risks losing a limb!
    Ask my girlfriend, Stumpy.
