Sky code for Samsung remote - STB mode
Discussion in 'Samsung TVs Forum' started by ukdy, May 6, 2007.
Tags:
  1. ukdy
    ukdy
    Apr 29, 2007
    365
    Solihull
    +36
    My Samsung remote has a STB mode and a code for Sky boxes that should let me control it. It however doesn't let me. The code was 031.
    Does anyone have any information that could help me.
    Thanks,
  2. ennerdale22
    ennerdale22
    Jan 13, 2007
    255
    Lancashire
    +6
    im also trying to find this out!
  3. skytecbvmo
    skytecbvmo
    Nov 6, 2005
    602
    +55
    Code for the sky remote is 0060 for the samsung remote i don't know but here is how you program it.
    How To Program Your Remote Control
    Turn device to be programed on.
    On the remote control, press a device key one (e.g., AUD, VCR, TV, or CBL). Press and hold SETUP until the selected mode key blinks twice, then release SETUP.
    Locate the four-digit code found in the list below that corrisponds with the device you are programming then enter that four-digit code. If performed correctly, the selected mode key will blink twice.
    (NOTE:If the selected mode key emits a long blink, the code is invalid. Repeat steps 2 and 3 and try entering the same code again.)
    Aim the remote control at the device ad press POWER once. The device should trun off. If it does not, repeat steps 2 and 3, tryin each code for you brand until you find one that works. If it still does not work, try searching for the code. (click here for instructions on how to search for your code.)
    Repeat steps 1 through 4 for each device you want the remote control to control.
