Sky+ Code for PW7
Discussion in 'Plasma TVs Forum' started by dylanfreak, Feb 24, 2005.
  1. dylanfreak
    dylanfreak
    Hi Folks :hiya:
    Any clever bods out there know the code to operate the Sky+ remote
    volume control for Panny PW7
    Sky+ web site lists loads of numbers but no mention of PW7
    Ta very much
  2. The Hemulen
    The Hemulen
    Dec 5, 2002
    518
    Cambridge, UK
    +19
    try using the 'standard' Panasonic TV one. I bought a Panny PW7 to replace an old Panasonic WS TV and didn't need to change the code at all!
  3. w3dal
    w3dal
    Aug 4, 2002
    5,031
    Chelmsford, Essex
    +584
    I used code 678 and controls my PW7 and Mediabox just fine!
    Dal
  4. RichardHannan
    RichardHannan
    I think it may depend on the age of your sky remote - I have 2 remotes (one from a dead system) and needed to use different codes for each.
    One was the code in the above post, the other was 065 (I think)
    Good luck
  5. dylanfreak
    dylanfreak
    Thanks a lot chaps
    678 fixed it
    :clap: :clap: :clap:
  6. JIMMY
    JIMMY
    hi how do i put the code in tryd pressing tv
    then 678 then tv
    doesnt work how do i do it
    jim
  7. w3dal
    w3dal
    Aug 4, 2002
    5,031
    Chelmsford, Essex
    +584
    dont u have to press tv then hold down red and select first. wait for the 2 flashes and then input the code followed by select.
    have a look at www.digiboxes.net
    Dal
  8. JIMMY
    JIMMY
    cheers w3dal worked a treat :clap:
    jim
  9. w3dal
    w3dal
    Aug 4, 2002
    5,031
    Chelmsford, Essex
    +584
    No problems Fella.....
    Enjoy.
    Dal
